Restored JDX8
mgabl072
Restored JDX8
Post by mgabl072 »
Completed restoration of a 1973 JDX8 (serial JDX8009382M). I am particularly happy with how the bogie suspension turned out. Thank you to all the members of this site that provided either parts or advise.
Pictures attached.
mgabl072
Restored JDX8
Post by mgabl072 »
Picture of engine compartment.
79 Spitfire
Restored JDX8
Post by 79 Spitfire »
NICE work!!!!!!!!!
James
1979 Spitfire 340
1980 Trailfire 440
T-Bone
Restored JDX8
Post by T-Bone »
Beautiful x8. hope my x4 turns out half that nice.
T-Bone :beers;
Restored JDX8
Very nice!
Will_jdx
Restored JDX8
Post by Will_jdx »
WOW!!!!! I hope my 74 X6 and X8 turn out that nice!!! Where are you located?
Will
1974 JDX6, 1974 JDX8
mgabl072
Restored JDX8
Post by mgabl072 »
Thanks for the compliments.
I am located in Belleville WI which is south of Madison about 20 minutes. I would say from Burlington WI about 1.5 hour drive. I am always up for meeting with other JD nuts to talk sleds and such.
Danzig
Real Name: Paul File
Restored JDX8
Post by Danzig »
:beers;
Cabindweller
Real Name: Jerry Zebro
Restored JDX8
Post by Cabindweller »
Excellent Job! Two thumbs up!
Jerry
Liquifire 4/6
Restored JDX8
Post by Liquifire 4/6 »
Fantastic Job! Congrats on an excellent restoration.
Peter from Roblin, Manitoba
JD600
Restored JDX8
Post by JD600 »
How do you guys get your fuel tanks to look like that? :?:
ChickenRat
Restored JDX8
Post by ChickenRat »
Nice job on that sled. You should be proud.
Robb
mgabl072
Restored JDX8
Post by mgabl072 »
Fuel tank question. First off start with a good fuel tank that is not all rusted and beat to hell. They are around enough that if you do not have a good one then go looking at a salvage yard. Make sure to check the inside too. The easy off and bolts takes care of the rust on the inside. On the outside I degrease it with engine cleaner, used WD40 and steel wool, about a 6 pack of beer and 3 hours in the shop just basically cleaning/sanding every inch of paint and rust. Then a coat of primer and then 1 light coat of I used high temp metalic grey paint. I am not an expert but I forsure learned that inorder to get good paint jobs you have to prime it, otherwise it will always turn out not as nice as it could have.
I thought about using the bead blaster but I was afraid it would be too rough but maybe not and it sure would have turned a 3 hour job into about 20 minutes. But also would have not got to drink the 6 pack as easily.
medicineman
Restored JDX8
Post by medicineman »
Wow, That is beautiful MATT. You aren't going to drive your restored "8" I hope
I500
Real Name: Chuck Moser
Restored JDX8
Post by I500 »
SWEEEEEEEEEEEEEEEEEEEEEEEEEEEEEET................Great job
