Parts List for Charity Sled
Here is the list of parts that we need for the charity sled. I would prefer NOS but if you have perfect used parts we'll sure consider them. Items with an * are high-priority and needed badly!
M68207 Fuel Tank Pad
M68647 Engine Fan Shroud
M68609 Engine Screen
M68189 Intake Hose
*AM54355 Ignition Switch with key
AM55257 Wiring Harness
*Windshield Prefer not a cheap one that lays back
The following items have already been donated:
*M67685 Handlebar Grips (2)Donated by Snow City, Bronson, Michigan
*M68611 Fuel Tank Fitting Donated by Bob Amber
*M66245 Spindle bushings, need all fourTodd JDT
*M68313 Rear Flap Support - Will Re-Use
M67931 Jackshaft Will Reuse
AM54671 Brake Rotor JDR, on hand
M68646 Exhaust Springs - DA
AM55561 Instrument Panel - DA
M68020 Belt Guard Wing Nuts (2) - DA
AM55148 Glove Box Door JDROn Hand
AM54912 Ski (2) Sent to Clack for rebuild
AM55099 SpeedometerJDROn hand
M68249 Throttle BlockWas able to purchase/DAOn hand
AM54782 Kill Switch JDR
M68651 Rear bumper Frankie Lovell donatedOh hand
AM52305 Taillight AssemblyEric AndersonOn hand
AM55052 Handlebar faceplate JDROn Hand
AM53554/AM55301 Speedometer Kit JDROn hand
Drivebelt (Prefer not NOS for durability)MATT
AM54384 Chain TensionerRich, On Hand
M68541 Front bumper JDR
AM55130 Chrome Shocks (2)JDTTodd
M68632 TPR Panel rightMarshall
M68939 TPR Panel left Marshall
M66128 Chaincase SealJDR
M67934 Drive Sprocket (2)JDROn hand
M68263 Drive Shaft (hex)JDR
AM52346 Tachometer Kit Pat(HarleysportsterOn hand
M68611 Fuel Tank Fitting Sprailfire340
Rear Flap Horicon Joe
Ski InsulatorsHoricon Joe
Clutch Kit JDROn hand
Complete Graphic KitWebmanOn hand
Drive Sprockets (2) JDROn hand
TM1222 Service Manual On loan from JDR
Fuel Line and Filter Durand Motorsports, On Hand
*AM54807 Gas Cap/Guage donated by The Partconnection-On Hand
AM53955 Choke Cable Assembly / I now believe that I can use the original cable
This is a long list I know and most likely not all parts can be found but it's worth a shot. PJ will most likely post additional items from the engine/clutch area.
Finally, even if you can't provide parts you can still be a big help by donating funds, send those to Matt per his instructions on the front page.
Thanks all,
M68189 Intake Hose
Thanks all,
Last edited by WinnipegStPaul9 on Wed Aug 26, 2009 4:46 pm, edited 35 times in total.
Re: Parts List for Charity Sled
Which sled is this for, the 340 or Sportfire?
- guitardude081
- Real Name: Jack Durand
DA,
Good to talk to you today. I poured through my parts, and here's what I found. I've got a butt load of Speedo drive keys. My angle drives are all 2:1 and backwards rotation for the DD sleds. I've got a very nice original key switch with a non-faded nut. The key is universal and you can pick it up at any locksmith shop, or JD dealer. All of my original Deere keys with the "JOHN DEERE" etched on them are rusty. I've got a used taillight assy that is in great shape. There's no paint separation or rust, but if memory serves me, it's on the shelf due to a grounding issue causing an intermittent light. I'll try to test it on the Liquifire in the near future. They are still available w/lens through Deere for around $20 for a last resort. Those skis I have are the 10-24s we were talking about...rats! The chaincase seal is the same as Polaris part# 5411497. It's better to go with a new one vs. one that's been in a bag for 30 years. If you guys find parts in catalogs such as DK, let me know and I'll get them to you cheaper. If PJ can't get a deal on engine parts, let me know. I can get teflon crank seals for most Kawi JDs as well. I've got a beautiful KPH speedo with around 1500km on it. I've got a nice 8000rpm tach from the Xs/Os. You could probably make that work on the sporty harness. Check w/ some of the guys who bought a lot of DKtrader parts. I remember seeing a bunch of wiring harnesses sold back then. Other things to look at....Spindle bushings, leaf spring shackles (are they loose?), Horicon joes handy dandy spring sliders, matching up the shocks to ones w/ the same dimensions (I always use '72 A/C Lynx shocks for the front and then I swap the bushings...new shocks are better for chrome to adhere to as well), hood foam or heat tape (I'd opt for heat tape. It's $50 per roll and should do 4 or 5 hoods) and the motor mount rubbers. Count me in for a good length of 1/4", 3/16" and 1/8" fuel line for the PJ circuit, Overflows and main lines and a filter for sure. Good luck commish and crew!
~Jack
~Jack
Owner, Durand Motorsports
1983 Trailfire LX
(3)1974 295/S
1975 340/S
(2) 1978 Liquifire
2003 Ski Doo Renegade 600HO
1983 Trailfire LX
(3)1974 295/S
1975 340/S
(2) 1978 Liquifire
I'll need to check on this, but I believe I have an NOS Spitfire speedo drive around here somewhere.
I believe I have a throttle block for my LIQ. Will that work for you? I need to get the PN off it.
Here is the link for money donations: http://www.jdsleds.com/donate.html
Don, I can help with some of this...and I will keep checking the inventory too.
AM54912 Ski (2)
AM55099 Speedometer
AM54782 Kill Switch - JDR
AM55052 Handlebar faceplate - JDR
M67931 Jackshaft
AM54671 Brake Rotor
M68647 Engine Fan Shroud Should have one NOS - JDR
M68314 Clutch Guard Decal
AM53554/AM55301 Speedometer Drive
M68541 Front bumper (WE REALLY, REALLY, NEED THIS) (Might have a good used one, need to check -JDR)
AM68528 Fireburst Decal for console - JDR
M68189 Intake Hose
AM52346 Tachometer Kit (not necessary but would be nice touch)
AM54912 Ski (2)
AM55099 Speedometer
M67931 Jackshaft
AM54671 Brake Rotor
M68189 Intake Hose
1980 Sportfire 440. DAwebman wrote:Which sled is this for, the 340 or Sportfire?
- guitardude081
FYI on the angle drives: They need to be for a Liquifire, Sportfire or Trailfire. The Spit/Snow/Sprints are made to go in the opposite direction because they are mounted on the opposite side of the tunnel and the rotation of the driveshaft in relation to the drive is opposite. They should have an arrow engraved on them as well as a ratio. There are 2 different ratios are for MPH and KPH.
~Jack
~Jack
1983 Trailfire LX
(3)1974 295/S
1975 340/S
(2) 1978 Liquifire
1983 Trailfire LX
(3)1974 295/S
1975 340/S
(2) 1978 Liquifire
Rats! I'll have to buy a Spit just to put that darn drive on something!
Hey Don,
I just won a Trailfire Speedo Kit off Evil Bay. I will donate the entire kit for the Sportfire. This includes the hardware, drive, cable, english 80 mph speedo, etc.
I also have several good drive shaft assy's with good sprockets. I will donate the best one to the project.
-Rainville
-Rainville
Excellent, thanks as always.!! Lindner has accepted the responsiblity of polishing the chaincase and cover! Thanks Brian. Would anyone be close enough to a Polaris dealer to buy the chaincase seal (Polaris part# 5411497) that Jack mentioned in an earlier post and mail it to me? DA
Don,
I have a bunch of NOS Deere chain case seals. While I generally agree with Jack about the hardening of 30 year old rubber (ie: NOS crank seals), I think the ones I have are in pretty good shape, still soft and plyable.
I will toss one in with your next parts shipement.
- Jekyll
- Real Name: Roger Jordan
Don,
I sent you an email about the seat but our power flickered as I was hitting send.
Please let me know if in't not there by late tomorrow.
Roger
Roger
Will do, thanks Roger. As of 22:30 it hasn't arrived.
