Lower gears in a LF
S_Kyle
Real Name: Scott Kyle
Lower gears in a LF
Post by S_Kyle »
As I wait for my seals to arrive for my 77 440 LF. I was reading the FTM I have and it says that the theoretical top speed will drop by 7-8 mph if I put the 21/39 set in. I belive that I have a set of 340 gears in storage somewhere.
As anyone done this swap in an early LF. If so, what were you impressions as far as performance goes.
Scott
Re: Lower gears in a LF
Scott,
I know one of the members here has a 76 340 cyclone with a 440 engine in it. His weight is on the heavy side and the 340 gears help out better with starting from a complete stop. If you do a lot of tight trail riding, it will be an improvement. If you do lot flat-out riding, the top end will suffer. By no means will the lower gears lift the skis, the early liquires were a heavy machine. Fuel mileage will also suffer slightly.
S_Kyle
Post by S_Kyle »
Fuel mileage will suffer. :shock: . It makes sense, but I am only getting 8 mpg in my other 77. I don't think I can afford worse mileage. I might try it and see if it is worth it or not. I can always put the 440 gears back in. Thanks for the info Pat.
Scott
