Motor Number TA440A-F202???
Scott L
Post by Scott L »
What is the difference of these two engine numbers?
TA440A-F202
TA440A-D202
Scott.
Re: Motor Number TA440A-F202???
If no one answers here, that might be a good question for the guys at kawasakitrax.com. They used a variety of engine versions over the years. The Deere versions didn't change much.
guitardude081
Real Name: Jack Durand
Post by guitardude081 »
The '79 Trailfire motor was different than the rest. The difference in the 2 is probably '79 and '80-'84. Don't quote me on that, but I'm thinking that's the case. The newer motor had a couple of extra ponies.
~Jack
Owner, Durand Motorsports
1983 Trailfire LX
(3)1974 295/S
1975 340/S
Trucker
Post by Trucker »
Those are both Deere motors but different years but thats all i can tell you since i am not that familiar with the Deere applications
manitobatrailfires
Post by manitobatrailfires »
I've been away from jdsleds since the snow melted, but bought another Trailfire this morning so I had to log in and get a JD fix.
TA440A are 440 Trailfire engines, as I'm sure you're aware.
The fourth-to-last digit is the year code. D is a 1980, F is a 1982.
Very little change to the TA blocks throughout their run, but the F202 is the exception.
There was a piston ring change between 1979 and 1980, although the pistons are the same size and any matched piston/ring set should fit any cylinder.
The heads, case, and crank are the same through all model years.
The F202 had unique cylinders and head gasket. Same pistons, same case, same heads, though.
It would be interesting if someone knew what the difference actually was. Have you taken these engines apart? can you see any difference?
Eric
1979 Trailfire 440, dad bought from Steinbach, MB JD dealership in 1980 with 1,200 mile and an aluminum tunnel on it, regular rider, 5,055 miles
1980 Trailfire 340, bought in 2008 with TA440A-C202 engine in it, regular rider, 6,250 miles, LF rubber track
1979 Trailfire 340, bought in 2009, in pieces and rough cosmetic shape, 440 cylinders ready to go in (need pistons still), no odometer
