1980 spitfire ?
1980 spitfire ?
my son just bought a spitefire and the guy he got it from said it would burn up the drive belt real fast
Re: 1980 spitfire ?
Might be a Clutch alignment issue, or there could be a front shaft bearing going out..
Ken
Ken
Re: 1980 spitfire ?
after checking the clutch buttons they are thin! would that maybe cause this? he is 9 and worked all summer 2 buy it i have 2 get it goin 4 him so any info u could send my way would b great. by the way how fast are these sleds ?
Re: 1980 spitfire ?
What clutch buttons are you talking about Drive or driven? IF drive yes it could be, if driven no not really, unless the movable face is riding on the cam ( alum on alum ) BUT they should be replaced if they are thin.3JDTIM wrote:after checking the clutch buttons they are thin! would that maybe cause this?
Speed will depend on which drive sprockets it has on it the 7 tooth or optional 8 tooth & how much your son weights, but probably not much over 40-45 MPH.
But they are a blast to drive..
Make sure you CK the front shaft bearings as these have a tendency to go bad, When they do they most of the time take the front shaft out also.. This might be your problem, as if they go bad they would probably make the brake stick also which could be why it's hard on belts.. Or it also could have wheels out on the suspension, to make it reliable for the winter it would be a good idea to pull the suspension & ck everything over good..
Ken
Re: 1980 spitfire ?
bearings are good. they seam tight anyways i found the problem they had wrong belt on it i think its spose 2 b a 1107 right?
Re: 1980 spitfire ?
A OEM M68715 belt should be 47.0" +/- .25 X 1.25" An 1107 is 47-1/8" X 1.25" So Yes I would say a new or very good 1107 should work.
Ken
Ken
Re: 1980 spitfire ?
Also make sure they didn't put spacers behind the bolt & big washer that holds the driven on to the drive shaft, this would space the driven out & make the sled start like in second gear.. the correct belt should ride right at the top of the driven when the sled is setting.
Ken
Ken
Re: 1980 spitfire ?
ok i got one on there had one laying around 4 once that looks alot better we got alot of work before we can test it out
Re: 1980 spitfire ?
You might want pop the cover off the drive clutch ( If it's still a 94C Comet Duster ) to make sure they didn't melt the pucks..
Ken
Ken
Re: 1980 spitfire ?
its still a 94 c after i get the cover off where are the pucks?
Re: 1980 spitfire ?
Right under the cover, the 94C only has a spring & 9 pucks.
Ken
Ken
Re: 1980 spitfire ?
they apear 2 b ok
Re: 1980 spitfire ?
You would be able to tell if they are melted as the edges are usually rolled or flattened out over the actual sides of the puck, where they come in contact with the cover..
Re: 1980 spitfire ?
Probably a good time to do crank seals as well just so you dont burn up the engine very easy to do on that engine and is worth the piece of mind.
Re: 1980 spitfire ?
yea ive got some found just waitn 2 get them i dont know how 2 put them in but i goin 2 find out how often do they need replaced?
