Piston markings
tipitup
Piston markings
Post by tipitup »
I took the pistons out of a 80 sportfire and am having questions as to whether they got back in the right way. there is an arrow and an E on the top of them. I have the arrow pointing to the E which is toward the exhaust. Let me know if that is correct.
thanks
Horicon Joe
Real Name: Joe Wanie
Piston markings
Post by Horicon Joe »
Sounds good to me ..........
Joe
tipitup
Piston markings
Post by tipitup »
thanks, you wouldn't happen to have a picture on the timing marks for the sportfire. I having trouble with it starting and it was suggested that the timing is off.
Horicon Joe
Piston markings
Sportfire ......... here you go .......
Joe
tipitup
Piston markings
Post by tipitup »
joe,
can you use a liquifire CDI in place of the Sporty's? I have acces to one, just wondering.
craig
Horicon Joe
Piston markings
My thought is no...........
It seems someone was just asking about this ...... check the posts
Joe
JDFanPa
Piston markings
Post by JDFanPa »
the lf cdi should work fine I used a trailfire cdi on a kawi invader which has a similar motor as a lf just make sure theres 2 wires white and a red that will plug into the stator a 3 wire connector for the coil and should have a black and a brown wire that go into the engine connector the brown will have a pigtail wire that gets grounded to the case
