For gits and shiggles
- Danzig
- Real Name: Paul File
I have a 440 F/C Suzuki engine out of a 87 AC Jag..runs perfect.
Do ya think it may bolt right into a 73 JDX 8?
Re: For gits and shiggles
Only one way to find out Paul....
No. (But it could be done)
Now to plant an even more evil idea: A 55 hp 76-78 Liquifire 440 motor would bolt right in...(except the carbs would be angled down a bit, but I am sure you could take care of that)
Way ahead of you Joe. Been planning that one for a wile. Still trying to figure out the best exhaust system for it.Now to plant an even more evil idea: A 55 hp 76-78 Liquifire 440 motor would bolt right in...(except the carbs would be angled down a bit, but I am sure you could take care of that)
Scott:
Think 75 800 or JDX-8 exhaust...not that the Watersboy and I haven't talked about making a 75 JDX-8LC in the past, just never got too it. Would be cool to see one on the VC next year!
Liquifire tunnel mounted heat exhangers should handle the cooling. Not much room for a radiator up front with that twisted pipe up there.
Good luck with it!
-Rainville
Good luck with it!
-Rainville
I have a straight 75 600 chasis with a large hole cut in the tunnel available and a 75 JDX pipe but was wondering about tring to make a pipe as I am just finishing up a welding coarse and would like to put my new skills to use. I was thinking the wider chasis would be an asset when increasing the power. I had a bad experence on a 800 last winter, machine was fine but I was a little sore the next day.
What ever happened to the guy that was going to put a 303 wankle in a Spitfire?
jdsledwheelman
i was thinking about the 80 liquifire and the motor from a wrecked 01 polaris xc 600 (twin cyl) i have lay'n around. but will the drive line handle it?
nick
nick
72 500
73 600
74 295/s, JDX6
75 340/s, 400, JDX8
76 440 liquifire
77 440 cyclone spitfire
78 spitfire x2
79 spitfire
81 spitfire
83 snowfire
73 600
74 295/s, JDX6
75 340/s, 400, JDX8
76 440 liquifire
78 spitfire x2
79 spitfire
81 spitfire
83 snowfire
I always figured a free air kohler in an early cyclone chasis with a dator hood would be great and could have theoretically have been done. I think a 650 from a speedway would be alot of fun in the Deere or maybe a king kat 800 motor?
feere the deere
I put a 78 Liquifire engine into a 73 JDX8 and used a 800 pipe on it without the
muffler on the end. It sounds and runs great. It is the WETX now. As soon as I can I will
post some pictures of it. It won a trophy at the Balls Beater Run this year. It looks
almost like it was ment to be, something the factory had built. My wife came up with
WETX and had decals made to look like the x series sleds have.
Was there any issues with clearance for the carbs? Did you install filters of some sort?
feere the deere
To have carb clearance I had to remove the glove box and for air cleaners I just installed aluminum air intakes
that mount with a hose clamp. The only part of the engine that shows is the resivoir and cap. Had to trim a cover
for that. Ron
for that. Ron
Good to know, I will have to consider that if I start the project.
- GreenFever
Have any pictures?feere the deere wrote:I put a 78 Liquifire engine into a 73 JDX8 and used a 800 pipe on it without the
'72 500 x2
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 600 missing engine parts
'75 800 not running
'73 JDX4 not running
'74 JDX6
'75 JDX8
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 800 not running
'74 JDX6
'75 JDX8
feere the deere
Hopefully by this weekend I will have some. Ron
