Fan bearing -295 twin Kohler
Are the fan bearings still available aftermarket? Or is it a common bearing? Didn't pull it apart yet, but can feel play in it.
DLDeere
- Real Name: Howard Olson
Re: Fan bearing -295 twin Kohler
I don't remember for sure, I rebuilt mine a couple years ago, but I think this is a standard aftermarket bearing that you can pick up at most farm supply stores or equipment parts dealers.
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
These just press in and out of the housing? Took a spare mag housing off a parts motor, had to beat the fan assy out of the bearings. Seemed like a tight press fit with a nice corrosion coating to seal it in there.... Just press out the old bearings and replace? With the aluminum housing I can't see putting alot of force on it.
