Wanted: Dimmer & Kill Switches for 00 series
- Sledder
- Real Name: Scott Jacobsen
I am looking for the following parts for 00 series (NOS or in good working order)
3 - Kill switches
3 - Dimmer switches
Scott
3 - Kill switches
3 - Dimmer switches
Scott
Re: Wanted: Dimmer & Kill Switches for 00 series
genuine nos has dimmers that work great but have a different face on them much better than nothing i think they are cat or something anyone able to help ? usually has them listed on ebay on genuine nos store kills can be bought from shadetree but sometimes out of them wade
- SpitfireKing
there's a place in Saskatchewan called Agri-Sport...they listed one's for JD's 73-78 all, for under $20.00....maybe look them up and give them a call...might have another source.
I tried the Doo Switch once. It fits loose in the JD grip after you remove the metal clamp.
(probably works fine for the 72)
The genuinenos dimmers work great! They are the same as many brands in yesteryear but not exactly the same as OEM JD.
- Sledder
Thanks guys, I will check out all of your suggestions.
Thank you for all the input.
Scott
Scott
- jeffreyrempel
Check this link out. I have bought from them:
http://recreationsupply.ca/catalog.html
Or I have some that work, but are missing the plastic on the buttons.
Jeff
Jeff
1972 400
1972 400
- SpitfireKing
I see they don't list the 72-79 switches for JD...only the TF and 80-84 switches.....too badjeffreyrempel wrote:Check this link out. I have bought from them:
Jeff
they seem to have a good listing of other JD stuff
- 80spitfire
- Real Name: Brian Kottke
I'd give Rich Acre a call If I were you. I guarantee he'll have them and he'll probably be the cheapest too. Here's his number 989-292-2624
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
75' 340/S Rider
77' Liquifire Rider
This dimmer switch will work fine on the older JD's.
The connect is diferent but the switch fits the grip.
You will probably never find a cheaper one.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWAX%3AIT
- Sledder
Thanks Todd.
