Lost lights 295/S
monte44
Lost lights 295/S
Post by monte44 »
I had my 295 out for a good ride last night and after about a half hour of riding I lost all lights and the tach stopped working any ideas. Also it's kind of boggy on the low end carbs are super clean 190,160 main 40 pilots once it gets moving hang on!! Does anyone know if there was a service change on how the floats are adjusted one book says level and another says 23mm for floats which one is correct?
Re: Lost lights 295/S
I would suggest starting the engine, pull the connector apart and measure the ac voltage output at the engine side of the connector.
If it is say zero to 5 volts at idle the problem is the lighting coil.
If it is say 10 to 15 volts than the problem is in the sled wiring somewhere.
Plug the connector back in. Unplug the voltage regulator and AT IDLE, measure ac voltage again.
If it is 10-15 then the voltage reg is shot.
If it still low than continue to isolate the curcuit that is pulling down the voltage.
Disconect the lights, tach, ect one system at a time until the voltage pops back up.
Once you know what curcuit or component is the problem you can repair or replace it as needed.
My bet is the regulator toasted out on you. Common problem and a cheap fix at less than $20 for a new one.
HoosierDeereMan
Real Name: Troy Miley
Post by HoosierDeereMan »
I had the same thing happen with a JDX8. The first time it was the voltage regulator and it blew the tail light bulb. The second time all the lights quit it turned out to be a bad stator. I bought a rewound one from Scott at Hewtech.
Troy
DLDeere
Real Name: Howard Olson
Post by DLDeere »
Any other thoughts on the float adjustment?
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
