Could anyone provide me with the jetting specs for a 76 Mercury 340 Trail Twister?
Mark
76 Merc Carb Specs
Re: 76 Merc Carb Specs
Fixed high speed jet is a 200
Jet needle E-ring should be second slot from the top
I can't find the pilot jet size.
There is a repair and parts manual here http://www.vintagesnow.com/Mercury.htmlif you need more info.
Ironically, the pilot is what I need. I'm running 30's right now but it still seems to be loading up.
I did some more digging and the parts manual shows 30s for a 340 and 35s for a 440. Maybe the e-clip is in the wrong place?
Webman,
Thanks for the help! Once I looked over the link you posted I could see that someone had installed the incorrect needle and seat. I put in some spares that I had here and now it take a half a pull to start and will idle perfectly. I'm quite impressed with the way it handles, not even the moguls in the ditches could shake the smile off my face.
Mark
Mark
