Adding heat exchanger to a dator
DLDeere
Real Name: Howard Olson
Post by DLDeere »
It's been recommended to me to add a heat exchanger from a Liquifire to my Dator if I plan to ride it much. Have any of you done this? Any tips or suggestions? Thanks for the help.
Howard
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Re: Adding heat exchanger to a dator
Howard, Use the one from a 80-84 Liquifire, They work a lot better & don't hold the mud like the 78 style does.. I can ck & let you know how we ran the hoses if you want?
DLDeere
Post by DLDeere »
Kenny, that would be great if not too much trouble. Now I need to find some. Thanks. Howard
DL Deere
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Howard, I forgot ours still has a Liquifire engine in it, you better find out from one of the other guys how they have there's set up with the Dator engine in it..
DLDeere
Post by DLDeere »
Ok. I think it would still work the same. I can get the plumbing diagram from the parts book. I'm sure someone else will reply. Thanks.
DL Deere
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Howard, PM sent..
JDXspec
Real Name: Dustin
Post by JDXspec »
Howard,
When I restored my Dator last yr I did install a LF cooler. But I used a 78 cooler. I could not seehow the 80 LF would fit in there. Even the 78 was a bit of a challenge at times. :bonk: Here are some pics. the setup worked well till the pto burned down. I still don't know why. it never got above 150.
liquidator plugs 005.JPG (77.32 KiB) Viewed 2148 times
liquidator 006.JPG (67.1 KiB) Viewed 2148 times
JDXspec
Real Name: Dustin
Post by JDXspec »
For good measure here are some pics of the LF eng installed after the dator eng mishap. :boohoo:
liquifidator 001.JPG (81.86 KiB) Viewed 2148 times
liquifidator 002.JPG (80.03 KiB) Viewed 2148 times
DLDeere
Post by DLDeere »
Kenny, Got the PM. Thanks. Howard
DL Deere
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
buck43
Post by buck43 »
JDX that is one sweat looking dator!
