It's been recommended to me to add a heat exchanger from a Liquifire to my Dator if I plan to ride it much. Have any of you done this? Any tips or suggestions? Thanks for the help.
Howard
Adding heat exchanger to a dator
DLDeere
- Real Name: Howard Olson
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Re: Adding heat exchanger to a dator
Howard, Use the one from a 80-84 Liquifire, They work a lot better & don't hold the mud like the 78 style does.. I can ck & let you know how we ran the hoses if you want?
DLDeere
Kenny, that would be great if not too much trouble. Now I need to find some. Thanks. Howard
DL Deere
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Howard, I forgot ours still has a Liquifire engine in it, you better find out from one of the other guys how they have there's set up with the Dator engine in it..
DLDeere
Ok. I think it would still work the same. I can get the plumbing diagram from the parts book. I'm sure someone else will reply. Thanks.
DL Deere
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Howard, PM sent..
- JDXspec
- Real Name: Dustin
Howard,
When I restored my Dator last yr I did install a LF cooler. But I used a 78 cooler. I could not seehow the 80 LF would fit in there. Even the 78 was a bit of a challenge at times.
Here are some pics. the setup worked well till the pto burned down. I still don't know why. it never got above 150.
- liquidator plugs 005.JPG (77.32 KiB) Viewed 2139 times
- liquidator 006.JPG (67.1 KiB) Viewed 2139 times
- JDXspec
- Real Name: Dustin
For good measure here are some pics of the LF eng installed after the dator eng mishap.
- liquifidator 001.JPG (81.86 KiB) Viewed 2139 times
- liquifidator 002.JPG (80.03 KiB) Viewed 2139 times
DLDeere
Kenny, Got the PM. Thanks. Howard
DL Deere
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
JDX that is one sweat looking dator!
