340 clyclone speedo problems
Jeff Miller
I just bought a orignal owner 76 clycone in great shape, I got it running and testing the results to find the speedometer is all over the place. I inspected the drive bearings and they seam good what should i look at next.
Re: 340 clyclone speedo problems
Sounds like the cable is binding, winding up, then unwinding. Lube the cable with a product for that, or graphite, something like that.
Jeff Miller
good idea i'll try that thanks
If it is a high mileage machine, chnaces are the main bushing in the speedo is worn out which can cause the needle to swing to full speed right away.
I too had speedo problems on my '76 340 Cyclone. I replaced the speedo and right angle drive. Thankfully I did. When I took the drive off, I saw that I had a bearing out on the drive shaft, that I never would've noticed. I had a big learning lesson with the right angle drive that I thought I'd share and maybe save you some time. I purchased what I thought was the correct drive for the Cyclone. The speedo didn't work, but the miles were counting down in reverse. After a 12 pack and a lot of head scratching over the paper work I received with the right angle drive, I realized the drive was for a SprintFire. Given the different mounting locations between the Cyclone and SprintFire, I finally realized the internal gears on the drives were in opposite directions. Rather than pull the drive off, I switched the internal gears, re-using the old gear, and she worked like a champ. Needless to say my speedo cable was good so i didn't have to re-route a new one. Thought I'd share my experience so you didn't have to drink as much as me to figure it out, even though that's half the fun!!
'76 340 Cyclone
'76 440 Cyclone
'80 440 Liquifire
'80 440 Liquifire
'76 440 Cyclone
'80 440 Liquifire
'80 440 Liquifire
- Joliet Jake
Good advice from everyone
WORDS TO LIVE BY.........whenever you see your speedo jumping............ CHECK THE DRIVE SHAFT BEARINGS!!!!!
72 300
75 LIQUIFIRE
76 LIQUIFIRE
78 LIQUIFIRE
78 CYCLONE
80 TRAILFIRE
81 SRX
83 LIQUIFIRE
83 SPRINTFIRE
88 650 INDY
94 MACH Z
2000 MACH Z
2005 MACH Z
S 35 BONANZA
75 LIQUIFIRE
76 LIQUIFIRE
78 LIQUIFIRE
78 CYCLONE
80 TRAILFIRE
81 SRX
83 LIQUIFIRE
83 SPRINTFIRE
88 650 INDY
94 MACH Z
2000 MACH Z
2005 MACH Z
S 35 BONANZA
