need help with my 1974 jdx4 special
i have been running light boulbs through my jdx4 four 4 years now and i am sick and tired of it
and i need some help.i put a new boulb in and the light gets bright and then it blowes i need help
NO MONEY NO FUNNY
Re: need help with my 1974 jdx4 special
there have been some posts similar to this i think most issues revolve around the voltage regulator wade
does anyone now how many grouns there are on a jdx4 special
NO MONEY NO FUNNY
well ... one main ground on the fan tower near the six pin square plug thats were most everything grounds to , the regulator hangs up above the primary though ,hmm ill look at mine wade
NO MONEY NO FUNNY
In case you haven't seen this:http://www.jdsleds.com/tech/wiring/74wiring.jpg
i still dont now were the six pin squere plug is could you be more specific
NO MONEY NO FUNNY
it is bolted to the fan tower under the external coils.
DE
DE
Replace the voltage regulator. My X4 Special was doing the same thing when I bought it.....replaced the voltage regulator and all lights work as they should. The voltage regulator is located under the instrument panel, on the left side. It should be a single wire regulator and grounds to the frame where it mounts.
sorry yes that is the one sounds like your reglator has laid down on you let us know how we can help wadejoshua16 wrote:is the six pin square plug the one thats bolted to the engine wade?
yah i kinda figurd it was the voltage regulater and i think its time to replace it
its now fun chaseing coyotes in the dark.
NO MONEY NO FUNNY
