According to the book yes. In order to keep both boogies centered between the lugs you have to leave 1 side of the track w/ at least twice the gap from the slide as the other side of the track.JDT wrote:Did you do a proper track tension and alignment procedure?
Super Powered Sportie
Re: Super Powered Sportie
Have you checked both of the drove shaft bearings?
What about all the idler bearings?
Either the track is severly stretched on one side or you have a bearing/wheel issue.
Yeah had it all apart to replace the driveshaft bearing. Ok could be a stiff boogie wheel bearing.
