Super Powered Sportie
O'Deere
Re: Super Powered Sportie
Post by O'Deere »
JDT wrote:Did you do a proper track tension and alignment procedure?
According to the book yes. In order to keep both boogies centered between the lugs you have to leave 1 side of the track w/ at least twice the gap from the slide as the other side of the track.
Have you checked both of the drove shaft bearings?
What about all the idler bearings?
Either the track is severly stretched on one side or you have a bearing/wheel issue.
O'Deere
Post by O'Deere »
Yeah had it all apart to replace the driveshaft bearing. Ok could be a stiff boogie wheel bearing.
