1979 John Deere Trailfire crank seals part #
JDFanatic19
im thinking of ordering these through dennis kirk. Also what would i have to do pay wise, never ordered anything online before! Anyways is this the right one?: https://www.denniskirk.com/winderosa/cr ... /14205.sku
Dillon Devine
Chatham ON
2 1979 John Deere Trailfire 340's. Also have seized 340 and 440 (later to be rebuilt)
1990 ski-doo safari (Dad's Sled)
Chatham ON
Re: 1979 John Deere Trailfire crank seals part #
That seal is 30mm x 62/63.5mm x 10mm which is correct for the PTO end, but you will need a 25mm x 62/63.5mm x 10mm for the MAG side. The easiest was to pay is by credit/debit card.
DE
DE
JDFanatic19
so that one is correct for pto side? so what do i do for the other the mag side?
Dillon Devine
Chatham ON
Chatham ON
I'll look it up for you tonight and get you the number.
DE
DE
JDFanatic19
ok thanx JD
Dillon Devine
Chatham ON
Chatham ON
The seal number may still be visible on the old seal. The JD Parts Cat. shows the same seal on both ends of the crank, aftermarket 1302R. Before you split the case, get a set of the " O " rings that are around the main crank bearings. The originals may break as you seperate the case.
As usual, it looks as though Pat is correct. The seal you found from DK should work on both sides.
DE
P.S., JD Fantastic19, you have a PM.
DE
Unless you are ordering other stuff from DK, go to your local sled shop and see if they are a Parts Unlimited distributor. They can get you the seal in less time.
JDFanatic19
ok thanx guys. i just plan on getting the two seals, but if i order both of those they will both fit?
Dillon Devine
Chatham ON
Chatham ON
Yes, they do use two of the same seal. I just added them on Newbreedparts.com. You're also going to want some Threebond to re-seal the crankcase if you do it yourself.
http://www.newbreedparts.com/index.php? ... uct_id=115
http://www.newbreedparts.com/index.php? ... duct_id=96
