Well after a day of drinking coffee, and mountain dew the following took place
The fuel line from the gas tank to the carb was replaced again with a new line, new clear inline fuel filter, a new impulse line installed with a very heavy gauge nylon line, 2 like new BR9ES's, compression checked at 180lbs on both cylinders, points were cleaned, I couldn't check the gap due to not having a feeler gauge, points should be set at .014 +/- .002. Carb taken apart one more time and checked. Added 1/4 bottle of HEAT to the gas. Drank a cup of coffee again, put on some music and cranked her up. No good again.
I forgot to mention, I went through an entire can of starting fluid to check for leaks, nothing was found to be bad.
Then I got to playing around, the manual stated to set the low idle and high idle set screws out at 1.25 turns. I have to laugh at this one. The low idle is now set out at about 5 turns and the high idle is about 2.25 turns out. Now guys this thing runs consistent at 2500RPM's and plenty crack on the throttle. Engine now starts with only a half pull when hot, yes I did say a half pull, she is running half way through the initial pull. Now I know I have the high idle to set yet when the white stuff hits the ground.
The dilema= 5 turns out on the low idle why??
2.25 turns out on the high idle why?
180lbs compression should be 125lbs. or so. Reasons so high, could be deposits of crap on top of the cylinders or stuck rings possibly. This may be why the carb settings are off from the manual. She isnt a new sled by all means.
After all this was done the sled sat and idled fine for about 15 minutes, I pulled out the plugs and here you go guys..........light brown!!
