wanted idler wheels
wanted idler wheels
hi guys need more parts for my jdx4 special.i need all three idler wheels im not looking to spend a lot right now.and i have one scorpion and one arctic cat idler wheel on the sled right now and still looking for another around the yard maybe a ski doo or a polaris thanks joshua
NO MONEY NO FUNNY
Re: wanted idler wheels
well after looking in the F.A.Q page i decided to try rebuilding my idler wheels and i need the reducer bushings/bearings and the rivets.im going to try the local jd dealer or at the new holland dealer or at tractor supply.any advice would be helpful.
NO MONEY NO FUNNY
I had a bearing out on one of the idlers on my trailfire, I just cut the metal on one side so I could push the bearing out and put a new one in, not the prettiest but works fine.
80 Sportfire
79 Trailfire 440
79 Trailfire 440
The bearings used in the idler wheels are metric, thus the need for the reducer bushings. The bearing OD is 52mm, the ID is 25mm, and 15mm wide. These are commonly known as a 6205 bearing, and are available from most sled parts suppliers.joshua16 wrote:well after looking in the F.A.Q page i decided to try rebuilding my idler wheels and i need the reducer bushings/bearings and the rivets.im going to try the local jd dealer or at the new holland dealer or at tractor supply.any advice would be helpful.
The reducer bushings are also commonly available as well. Here's an example:
https://www.denniskirk.com/04222.sku?ut ... medium=cse
For this application, I think you need just the small dia bushing.
As mentioned in the FAQ, the rivets are available from Mc Master Carr, or Wicks Aircraft. They are 3/16" dia X 1/2" long, with a low profile domed head.
http://www.mcmaster.com/#standard-rivets/=fbq3ii
hey i found some new idlers and i need to now what the od of the idler wheels are.
NO MONEY NO FUNNY
