1983 Liquifire electric start help
Mottsi
Real Name: Sean
Post by Mottsi »
I was fortunate enough to pick up an 83 Liquifire parts sled that has an electric start. Do any of you have a electrical schematic that you could post for me and/or give me some insight on installing it on my 83 resto project?
Thank you in advance!
Sean
Liquifire84
Re: 1983 Liquifire electric start help
Post by Liquifire84 »
Its in the tech manuals if you have them. If not I can scan and email it once I go back to work in a couple of weeks.
Brice
Hackinator
Post by Hackinator »
Here is a schematic from the 1980 Kawasaki LTD tech manual. Should help as a reference.
Hackinator
And here is all the insight that you need into doing it on a John Deere. http://www.vintagesnow.com/John_Deere_f ... tricStart/
JD600
Post by JD600 »
Hackinator wrote:And here is all the insight that you need into doing it on a John Deere. http://www.vintagesnow.com/John_Deere_f ... tricStart/
Lucky for Sean that he won't have to go through the process of making his own hole since its an 83. That right there looks like a lot of work :lol22: :thinksnow:
DE :sled:
DE :sled:
You're right Dustin!! Worst case scenerio here is removing two bolts that hold starter cover in place. :D
Hackinator
That is good news. The reason I have never put an electric start on my '80 is because I have no desire to go drilling holes in the crank case. I've learned something new today. Was '83 the first year that it was a cover plate?
JD600
Post by JD600 »
I believe it was about half way through the 82 model year that it changed. Sean, where is tha battery box on that thing? I can't figure out where they would put it.
Mottsi
Real Name: Sean
Post by Mottsi »
The battery box mounts in front of the clutch on the lip of the left TPR panel.
Thank you everyone for all the help.
Sean decided that we could install the starter at a later date in an effort to get this thing running and ready for a ride in mid-January. After watching him pull the cord tonight numerous times......he might change his mind again.
Hackinator
Must have excellent compression... In any case here are some images from a parts catalog that show a diagram and the corresponding parts list that may be of use when assembling and installing an electric starter kit into a Liquifire. Best of luck. Maybe once you get it installed, it will snow. :needsnow:
Diagram
Diagram
Parts List
Parts List
Parts List Cont.
Parts List Cont.
Hackinator wrote:That is good news. The reason I have never put an electric start on my '80 is because I have no desire to go drilling holes in the crank case. I've learned something new today. Was '83 the first year that it was a cover plate?
Hack,
FYI, if you need to cut the hole, the flywheel most likely will not have the ring gear.
