Reed Valves
tiny73
Real Name: Robert Brown
Reed Valves
Post by tiny73 »
A while back, there was talk that Boyesen reed valves from a Suzuki RM80 would work on a CCW engine. I was wondering what year they were using. I am looking for new reeds for my 1977 440 Liquifire, several of mine are rust pited and need to be replaced. I do not want to use the rusty ones and trash the fresh rebuild I am finishing. Any help is appreciated.
Thanks, Robert :needsnow:
Re: Reed Valves
DKTrader had a pile of these a year or two ago.
You may want to give them a call.
You will need the JD part number or they will just tell you no.
S_Kyle
Real Name: Scott Kyle
Re: Reed Valves
Post by S_Kyle »
I bought a few sets of reeds last winter for $3 a set, they are still out there and fairly cheap. I would guess that either rainville or Rich could supply you a set if Dk no longer has any.
TOYMECH
Real Name: Greg
Re: Reed Valves
Post by TOYMECH »
1980 Liquifire
1981 Sportfire
1983 Sprintfire
1982 Snowfire
1978 CC Liquifire
1979 340 Trailfire
1982 Trailfire Special
Mr. Deere
Re: Reed Valves
Post by Mr. Deere »
Wow I thought these were extinct!
Liquify
Boyesen Reeds in Kioritz
Post by Liquify »
Has anyone actually tried installing Boyesen Reeds from a Suzuki RM80 in their Kioritz? Any problems encountered? Information I recently received from Boyesen is that their part #610 should work on the stock Kioritz cage but their reed stop plate is also needed because of the dual overlapping reed design. I wanted to check with folks before I went any further. Thanks
Dick
WoodlandSerenade
Real Name: Ian Martin
Re: Reed Valves
Post by WoodlandSerenade »
Sorry to resurrect a dead thread, but do Boyesen sell their stop plates separately? I can only find the #610 reeds themselves and it doesn't seem like they include the plate with them.
*edit* Unless the stop plates are the metal pieces covering the screw holes on the reed */edit*
Holly, Mi.
'77 Liquifire 440
