A while back, there was talk that Boyesen reed valves from a Suzuki RM80 would work on a CCW engine. I was wondering what year they were using. I am looking for new reeds for my 1977 440 Liquifire, several of mine are rust pited and need to be replaced. I do not want to use the rusty ones and trash the fresh rebuild I am finishing. Any help is appreciated.
Thanks, Robert
Reed Valves
Re: Reed Valves
DKTrader had a pile of these a year or two ago.
You may want to give them a call.
You will need the JD part number or they will just tell you no.
Re: Reed Valves
I bought a few sets of reeds last winter for $3 a set, they are still out there and fairly cheap. I would guess that either rainville or Rich could supply you a set if Dk no longer has any.
Re: Reed Valves
1980 Liquifire
1981 Sportfire
1983 Sprintfire
1982 Snowfire
1978 CC Liquifire
1979 340 Trailfire
1982 Trailfire Special
1980 Liquifire
1981 Sportfire
1983 Sprintfire
1982 Snowfire
1978 CC Liquifire
1979 340 Trailfire
Re: Reed Valves
Wow I thought these were extinct!
Boyesen Reeds in Kioritz
Has anyone actually tried installing Boyesen Reeds from a Suzuki RM80 in their Kioritz? Any problems encountered? Information I recently received from Boyesen is that their part #610 should work on the stock Kioritz cage but their reed stop plate is also needed because of the dual overlapping reed design. I wanted to check with folks before I went any further. Thanks
Dick
Dick
- WoodlandSerenade
- Real Name: Ian Martin
Re: Reed Valves
Sorry to resurrect a dead thread, but do Boyesen sell their stop plates separately? I can only find the #610 reeds themselves and it doesn't seem like they include the plate with them.
*edit* Unless the stop plates are the metal pieces covering the screw holes on the reed */edit*
Holly, Mi.
'77 Liquifire 440
'77 Liquifire 440
