new carb seals, still leaking..?
johndeerejamie
Post by johndeerejamie »
i just installed a new gasket set on my walbro wd31 off a 77 john deere 300. i have assembled and disassembled it a couple times but cant seem to stop it from spitting fuel out the back off it.
is there anything i need to know that i may not be doing? i dont want to super tight those four screws in case they snap or strip the carburator holes.
let me know if anyone has came across this problem
thanks!
77 john deere 300
77 john deere liquifire 340
Re: new carb seals, still leaking..?
To clarify, where is the gas coming from? Is it spitting out from the intake or actually leaking from some where?
80spitfire
Real Name: Brian Kottke
Post by 80spitfire »
It sounds like you may need to adjust the metering lever. I had the same problem with one of my WD's. If it's not adjusted right it will leak out of the overflow.
Brian
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
johndeerejamie
oh ok ill check it again. its coming out the back of it (the side thats pointed toward the engine)
where is the overflow located?
its hard to tell because its awkward to pull it and look at the same time but it looks like its coming out from in between one of the fuel pump plates....
thanks guys!
77 john deere 300
80spitfire
I don't remember exactly where it is because it's been a while, but that does sound right.
Brian
72' 500 Restored
75' 340/S Rider
77' Liquifire Rider
kreechur
Post by kreechur »
My 76 400 was leaking fuel from between the plates when i rebuilt it last year, took a couple times to disassemble and reassemble, but i finally found a small bur on the metal from a screwdriver when i took the plates apart. I carefully cleaned that up and it was sealed from there on out.
  • 2 1970 Moto-Ski MS-18
    2 1969 Mercury 250ER
    2 1971 Evinrude Skeeter
    1 1979 JD Spitfire 340
    1 1980 JD Trailfire 440
    1 1976 JD 400
    1 1974 Scorpion Whip
    1 1989 Ski-Doo Formula MX/LT
    1 1994 Ski-Doo Formula STX
johndeerejamie
i was at it again today and am ready to give up!
i have taken it apart many times trying different things. I can confirm that it is leaking out from a little overflow hole thats in the second plate from the bottom.
i have adjusted the metering arm up and down and nothing seems to change it. it starts for a second and then gas starts spitting out and it wont start after that.
im really not sure what it is, and have reached my boiling point with it
77 john deere 300
Are you sure you have the carb lines hooked up correct?
The fitting on the side is the impulse line that goes to the engine case.
johndeerejamie
yup 100%
77 john deere 300
johndeerejamie
im wondering if maybe a gasket is leaking internally and causing gas to enter somewhere its not supposed to and is being spit out. the diaphram kit i got is made by spx or something like that, i heard good things about them.
77 john deere 300
All I can think is either A: like Brian said one of the ridges on the plates was ground down, B the gasket kit is defective, C it's assembled incorrectly.
johndeerejamie
i gave up and am looking for a new carb. does anyone know which ones work? theres a wd 35 on ebay but not sure if it will work or not...
one last thing, that metering level arm...its supposed to be a hair above the actual carburator housing if you are holding it upside down correct?? its kind of difficult understanding it in my manual.
77 john deere 300
johndeerejamie
Just to update this for reference, I bought another carb gasket kit, it was a winderosa and it is now running fine. The SPX or whatever brand didn't work.
77 john deere 300
klonteig
Real Name: Jordan Klonteig
Post by klonteig »
Out of curiosity, where did you buy the winderosa kit from? Would you happen to still have the mfg part #?
Jordan
1-1/2 JD300E's
I have the Winderosa Walbro fuel pump kits: http://newbreedparts.com/index.php?rout ... duct_id=93
