Thank you,
Craig, 920-763-4954
Horicon, WI
1-CCW recoil with Canadian maple leaf, good working shape, no break or chips in casting, Black paint chipping. $35
2-John Deere Operators Manual for JDX4, JDX6, JDX8 Snowmobiles M64455, Issue F3. Manual has some wear and marks on cover and pages, no cuts or tears. $15.00
3- JD Drive sprockets, never used NOS, 8 lug, hex center with metal insert, AM54216 possibly, $25 a pair, more than three pair $20 each pair
4- Dash/instrument panel with brush steel face plate possibly AM55348, no dents or breaks, only worn where choke and ignition was mounted, used little.
5- NOS Dashes/Instrument panel M63817 (JDX8), these have never been mounted, no wear. Great for restoration/museum sled. $35 each
6- NOS, Drive axle bearings Fafnir RA 100 R, never used they have the center piece coming out from the bearing, rear axle I believe. $20 a pair or $80 for 10 bearings.
7-Air Box with tube, AM54759, looks new not sure if it was used $20
8-Carb Jets, pin jets, and carb needles (jet's $1 each, Needles $2 each), large assortment
9-JD Secondary clutches, used but in solid condition, long time on shelf, $50 each, two sizes
10- Salsbury clutches three look new and one is used,
11- Ski Shock AM54759, used $10
