121 track swap
smitfire
Real Name: Dustin Smit
121 track swap
Post by smitfire »
I started a 121 track swap today, I was able to use the original suspension holes so far. I have lots of slop left in the track and im out of adjustment.
Maybe rail extensions?
The suspension is way shoved up in the rails but so are new sleds?
smitfire
Re: 121 track swap
Post by smitfire »
2
TASKY
Re: 121 track swap
Post by TASKY »
Wycrumb a member on this site put a Polaris suspension in his Sportfire. Not sure how to make a link try searching 121" track in a sportfire (that is the title of his post) or search his posts. Looks like you are on the right track. Keep us posted as to what ends up working. I know several of us are out there looking for the hook up (more traction).
TASKY
wycrumb
Re: 121 track swap
Post by wycrumb »
What suspension do you have in there?
Wycrumb
'82 Kawasaki KZ650 CSR
'74 John Deere 300
'72 John Deere 400
'73 John Deere 400
'73 John Deere 600
'80 John Deere Sportfire 440
smitfire
Re: 121 track swap
Post by smitfire »
1984 Polaris indy trail is what im using
Re: 121 track swap
Smit,
While I personally hate drilling extra holes in the tunnels of vintage sleds, I believe that is exactly what you need to do to make this swap work correctly. I would suggest measuring the doner Indy's mounting holes in relation to the drive axle.
I hope this helps,
-Joe Rainville
smitfire
Re: 121 track swap
Post by smitfire »
JoeRainville wrote:Smit,
I hope this helps,
-Joe Rainville
Joe, I hate drilling holes too. What is your theory for moving the holes?
427cobra
Real Name: Eric
Re: 121 track swap
Post by 427cobra »
If you measue the hole placement on the donar sled...you can transfer the measurements to the Sportfire. This will give you the correct placement of the skid in the new tunnel..
Re: 121 track swap
Smit,
Pretty much as Eric said it. Take measurements from the drive axle hole to the suspension mounting holes from the doner Indy. Or, you can make a cardboard templet to get campture the same dimentions. I would use the top of the tunnel for reference, but check it out with the suspension next to the sled to make sure you have the correct attitude of the suspension since your putting the longer travel skid in a leafer.
I hope this helps,
wycrumb
Re: 121 track swap
Post by wycrumb »
That suspension must be shorter than the mid 90's stuff that I used? I suggest you find a suspension like I used and you should not have to drill different holes, I didn't.
Wycrumb
'74 John Deere 300
'72 John Deere 400
'73 John Deere 400
'73 John Deere 600
