1982 Liquifire resurrection
TASKY
Re: 1982 Liquifire resurrection
Post by TASKY »
Nice!!!
427cobra
Real Name: Eric
Post by 427cobra »
Nice sled Paul! Youre making better progress than me...
Looks like youll be ready for the HOF ride... :letitsnow:
How do you like that HSR ignition?
Eric A.
Danzig
Real Name: Paul File
Post by Danzig »
Thanks Bill !!
Eric...I would not trade this for a 1980 ever !!.. One to two pulls and she purrs. I love it.
That's one nice sled you have there Paul
Nice work there Paul.
Hey Bob, you reading this????
DeereKid9
Real Name: Bob Amber
Post by DeereKid9 »
Yep! If you mean me?:?:
Bob A.
Sent from my DROIDX using Tapatalk 2
Sorry Bob. I meant the famous Mr Bob.
pwgsx
Post by pwgsx »
How did you put the crank seals in with only pulling the bottom case off?
Danzig
Post by Danzig »
step by step here ya go...
remove the black engine mount bracket, then remove the flywheel, then remove the stator and the black engine mount bracket with the flywheel housing due to the wiring for the stator goes through it, next remove water pump and hose leading to thermostat housing, next remove gear drive cover for the waterpump and oil pump, flip engine upside down remove all bolts holding the halves together, gently pry off the bottom half, next grab ahold of crank on both end and pull it towards you about and inch keeping pistons inside the cylinders, remove mag seal. PTO seal is in the gear case cover.
Danzig
Post by Danzig »
Danzig wrote:step by step here ya go...
remove the black engine mount bracket, then remove the flywheel, next remove water pump and hose leading to thermostat housing, next remove gear drive cover for the waterpump and oil pump, flip engine upside down remove all bolts holding the halves together, gently pry off the bottom half, next grab ahold of crank on both end and pull it towards you about and inch keeping pistons inside the cylinders, remove mag seal. PTO seal is in the gear case cover.
Paul,
Did you change the inner seal behind the oil pump gear?
Danzig
Post by Danzig »
yep...sure did
427cobra
Real Name: Eric
Post by 427cobra »
What trick did you use to get the gear off? Seems that may be tough with the crankcase in the way..?
Eric A.
69camaro
Real Name: Duane Gjerseth
Post by 69camaro »
Hey Paul,
Nice work. The Jackson county Black River Falls area trails are open. You should come up and ride that baby in the land of cheese. It's snowing like crazy here right now.
:letitsnow:
75-340/s
76-340 Liquifire
77-440 Liquifire Custom
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
81-Kawasaki 440 Invader
Danzig
Post by Danzig »
Eric,
Plenty of room, just pull the entire crank out with the piston attached to it, but dont go to far with that you dont wana pull the piston out the bottom of the cylinders. Once you have the crank pulled back, lay the engine on its side so you wont fight the pistons falling back in, which isnt too likely to happen due to the compression, leave the spark plugs in.
