Wanted...1980 Liquifire Suspension Shaft/swing arm
Danzig
Real Name: Paul File
Post by Danzig »
Wanted-
1980 Liquifire Aluminum suspension shaft and swing arm.
This is the aluminum shaft that usually is found to be stuck in the swing arm in these machines.
This shaft has the threaded holes in the ends that is used to mount the suspension into the tunnel.
Needing this aluminum shaft and the swing arm it mounts into in the rear suspension.
Re: Wanted...1980 Liquifire Suspension Shaft/swing arm
Paul,
With your talent, I thought you would be able to make a new shaft and repair the swing arm.
Since the pivot shafts are no longer available, I fabricated new ones. I purchased Air-Craft quality aluminum round stock from McMaster Carr, cut pieces to the proper length, drilled and tapped the ends for the mounting bolts. I drilled a hole in my wood bench top for the pivot shafts to drop down thru. I used a piece of scrap wood to clamp the shafts into and hold them in center with the drill press.
Danzig
Post by Danzig »
My talent... :bonk:
patience is thin these days and burning the candle at both ends doesnt show lots of time for projects....gotta get this Deere on the snow...its my destiny.
Mid 50's here this Friday...WTF ?
There goes the snow.... :bonk:
Paul, I might have one but most likely the shaft is "stuck".
mike817o
Post by mike817o »
Paul I have been making new swing arms have one on the jig let me know if still in need of one.
'72- 400 x2, 500
'74- JDX4 Specialx2, JDX6x3
'75- 300x2, 400, 800x2 JDX8
Paul, I believe I have a good aluminum shaft if needed, but no arm.
Danzig
Post by Danzig »
waiting on one other person on another forum, I will let you all know.
thanks you guys
jimmy245
Real Name: Jim Erlandson
Post by jimmy245 »
Guys,
Since threads on my alum shafts (80 Liquifire) shot, decided to go with steel shafts and be done with it. Also installed zerks on shaft tubes to keep grease inside.
Also fabricated new shaft that shock is mounted on. Original was aluminum but pretty badly bowed. Again went with steel and machined ends so it fits like old one.
Obviously a little weight gain with steel, but don't have to think about them anymore, just grease them through zerks once a season.
If you do go with steel, get cold-rolled which is much more precise spec than standard stuff.
Jim
Bought brand new '80 Liquifire in '79. Sold when I moved to Alaska in '81.
Now restoring '80 Liquifire from bottom up.
69camaro
Real Name: Duane Gjerseth
Post by 69camaro »
Pat, are you making wooden swing arms? LOL
75-340/s
76-340 Liquifire
77-440 Liquifire Custom
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
81-Kawasaki 440 Invader
Yea, first proto type still in the R & D phase.
