Rockwell 2F440-8
Rockwell 2F440-8
while picking up some spitfire parts, i somehow managed to buy a Rockwell 2F440-8. its a two cylinder, single carb motor. the seller had put the spitfire 94c clutch on it. I've tried to do some reasearch on this motor and find that Rockwell is related to JLO and Cuyuna. Its got good spark and 130# compression on both sides. is there a way to determine what it came out of? what's it worth? thanks, keith
- 003.JPG (203.28 KiB) Viewed 2148 times
Keith
Normal, IL
80 Spitfire
Keith
Normal, IL
80 Spitfire
Re: Rockwell 2F440-8
I agree, looks like Scorp motor mount. If you were closer, I'd be interested. But, I'm far from normal....
keith i was looking thought my fathers service manual and the only thing in that book that has that engine number is a 1974 columbia C-440 with a JLO 2f-440-8 and a 1975 C-440 with a JLO 2f-440-8.and a 1972 scorpion stinger 2 with a JLO 2f440/3 and a 1975 ski whiz mf444t and mf444wt and thay both had JLO 2f-440-7 hope this helps.
joshua
NO MONEY NO FUNNY
keith i showed my brother this post and asked him what the numbers were on his 1974 super stinger and his numbers are 2f-340-6 my fathers book only said 2f-340.and i asked my father what he thought about the engine and he said it looked like a 1973 scorpion engine i think it came of a 1974 with a 1973 carberator or a 1973 with a 1974 recoil hope this helps.joshua
NO MONEY NO FUNNY
hey josh, thanks for the info. i should have posted here that i did some horse tradin with that motor to get a "low mileage" 79 trailfire. the speedo sez 311 miles but it looks like its sat outside for the last 30 years. i did hear the 340 run on spray into the carb so i may be using parts off of this one to get my 440 running on more than one cylinder. i'm thinking of doing crank seals and paint jobs on both this summer, than unloading the 340 next time the snow flies.
Keith
Normal, IL
80 Spitfire
Keith
Normal, IL
80 Spitfire
keith happy to help i dont now much on jlo or rockwell but i hope that helped.joshua
NO MONEY NO FUNNY
