What color silver?
What color silver?
Well, now that I finally have my 83 TF LX going I am ready to re-paint the hood. Is there a common color in rattle cans out there that is close to the WinterFrost Silver used from the factory. I'm not really wanting to spend a bunch of money on paint but want it to look right. Any help would be great! Thanks!
Stteve
Stteve
1979 Spitfire
1979 Trailfire 340
1980 Trailfire 340
1980 Trailfire 440
1982 Liquifire
1983 Trailfire 440 LX
1979 Trailfire 340
1980 Trailfire 340
1980 Trailfire 440
1982 Liquifire
Re: What color silver?
The quick answer is "check the FAQ section" it's in there. The longer answer is that the silver is the same as the "Argent" silver used by Case-IH for their tractor wheels. If you have a Case-IH dealer near by you're in luck.
Is that the same argent silver used on older gm ralley wheels?
1979 Spitfire
1979 Trailfire 340
1980 Trailfire 340
1980 Trailfire 440
1982 Liquifire
1979 Trailfire 340
1980 Trailfire 340
1980 Trailfire 440
1982 Liquifire
I've used this silver to repaint tractor wheels several times. It tends to run easily, so my advice is to be patient and even err on the side of meticulous.WinnipegStPaul9 wrote:The quick answer is "check the FAQ section" it's in there. The longer answer is that the silver is the same as the "Argent" silver used by Case-IH for their tractor wheels. If you have a Case-IH dealer near by you're in luck.
Argent is the French word for silver; I have no idea why there is a French language translation on every container of CIH paint, especially when the parent company is Italian.
This was the paint used by kwc for the charity sled. He would be a good guy to ask.
It matches JD Winterfrost?
Standby Pat, I'll check again with Kevin.AirborneX4Special wrote:It matches JD Winterfrost?
I always though French was a kind of universal thing. Seams that everywhere you go people enjoy it.
1979 sleds no after 1979 yes.
Clay
Clay
Clay Gerfen
My Sleds
1 1980 Trailfire 340 = Less than five hundred orginal miles
1 1980 Trailfire 440 = My Test Dummy
1 1980 Liquifire = Future race sled
1 1978 Spitfire
1 1979 Spitfire
My Sleds
1 1978 Spitfire
1 1979 Spitfire
Here's the response from kwc, sorry I was wrong. The charity sled paint was a camera matched, custom blend and I don’t have the mix info anymore.
Copy. No worries. I just get all intrigued about such simple things.
Don, you're not wrong, there is a post about that in the FAQ, it's just not what Kevin used.
