I'm trying to get done with a 78 Liquifire that I've been working on at my usual glacial pace. The rear suspension had no movement so I dropped it out. I had hoped that it would be something simple, but both cross shafts are frozen tight. Before I do something stupid I need to see if anyone has found a good way to get aluminum shafts out of steel tubes...
1978 Liquifire Cross Shafts
Re: 1978 Liquifire Cross Shafts
Muratic acid Is the best way I've found then have new shafts made , wade
X2lwb140 wrote:Muratic acid Is the best way I've found then have new shafts made , wade
While I don't disagree, there's more than "one way to skin a cat" and somewhere on this website are the other ways. I just don't know where so you'll have to search. Just plan on having new shafts made, that will at least make you quit worrying about saving them.
i like the acid deal because it seems like no matter what if i try and get the aluminum shaft out i end up damaging the suspension arm and then i am in need of both parts !! i think i may have an extra set of shafts if you need them thanks wade
Here are some of the earlier posts.
http://www.jdsleds.com/community/viewto ... aft#p92088
Thanks for the input! I had thought about using heat, but was afraid of the results listed in the last post. I'm going to try the muratic acid method & see what happens. I had already figured I's have to make new shafts. I may even have some shafts laying here from a previous sled repair.
Thanks again for the responses.
I've gotten several of them out before without destroying them, with heat, a bolt threaded into the end of the shaft to hit, and a hammer.
Matt is right , I think we are the doomsday Crüe that have had ones that won't budge at all , but like Matt says some of them will come out with a little love and finesse
