looking for piston circlips for my 80 Trailfire 440 as i lost one during disassembly!
thx
Lloyd N
Beausejour, MB, Canada
204-268 5565
80 trailfire 440 piston circlips wanted
luvzvintage
Ryker Carruthers
- Real Name: Ryker Carruthers
Re: 80 trailfire 440 piston circlips wanted
When In Doubt, Throttle Out
luvzvintage
$26.00 shipping min. plus fees
I have them as well, but you would be better off finding someone in canada that sells them if that's all you need.
Sent from my DROID3 using Tapatalk 2
luvzvintage
thx matt
how much to ship to Canada via USPS?
Postal code: R0E 0C0
I mite as well get a couple of them while im at it.
This seems to happen a lot. They could put a couple of circlips in an envelope and mail it for the cost of a letter, but they put them in a small flat rate box that is still 99.99% empty. Some companies are better at recognizing how silly this is. I wonder if you called them if they could put them in an envelope? It could be that the automated system uses a small flat rate box as a minimum.luvzvintage wrote:$26.00 shipping min. plus fees
That's true, I could just drop them in a letter envelope. Looks like postage for that is only 85 cents to Canada. I'll send you a PM Lloyd.
EDIT: I just did a lookup on JDparts, and the circlip part number (M68071) is still used on lawn tractors, so you can pick them up at the dealer too.
luvzvintage
Thx all! I luv this site!
I'll check with my local dealer here and let u know how that goes!
regardz
Lloyd N.
Beausejour, Mb, Canada
regardz
Lloyd N.
There is something very satisfying about going into a JD dealer and picking up parts for a sled.
