What Liquifire Seconday Sheave do I have ?
Herd
Post by Herd »
I have a secondary drive of of my 83 Liqiufire that also has a 102c clutch on it. I am wondering if the secondary sheave was also switch to accomodate the narrrower belt. The part number on the secondary does not line up with the parts books. The part numbers off of it are AM54647, cam M68534, and AM53995.
Re: What Liquifire Seconday Sheave do I have ?
Parts book doesn't recognize any of those numbers. must be casting numbers.
Herd
Post by Herd »
Yes they are all casting numbers. Is there another way of identifing what I have?
ljm
Real Name: Lloyd
Post by ljm »
They are part numbers JD has always had part numbers cast into most parts, Still do on new stuff.
But the numbers do not show up.
Several Deere's
Several Kawasaki's
ACSCC #1534
427cobra
Real Name: Eric
Post by 427cobra »
Im not sure if there is a differnce in the secondary sheaves...?? I would just shim the secondary accordingly to get the right belt deflection/tension.
Im wondering if the differnt part number comes from the shims that were included in the clutch assembly.
Eric A.
I do know the limiter washer thickness was as follows:
M69652 ~ .190" ~ '83 Liquifire w/TR800
M69208 ~ .120" ~ '82 Liquifire w/TR800
M68665 ~ .260" ~ '80-'81 Liquifire w/102C
There is a note in the fine tune manual that basically says if you experience belt failures on an '82 Liquifire, due to the belt jumping off the drive sheave, to change the limiter spacer to M69652.
The fine tune manual also states that M68534 is a casting number for cams number AM55070 and AM55357
