Camoplast track on a JD Trailfire?
Liquifire 4/6
A 1982 Trailfire 340 showed up this past sunday at the Roblin/Makaroff, MB Vintage Derby and I happened to notice it had a rather deep lug all rubber track on it. I asked the owner where he got the track and he said he just recently acquired the machine and the track was on it when he got it. I rolled the track over and it was stamped Camoplast and had about a 1" lug height. I did not notice a part # on it anywhere. The suspension was a totally stock JD unit. I did not have a measuring tape with me to measure the pitch, but I'd guessed it to be 2.5" pitch and if I was correct in my guess, the sprockets must have been changed. I hope to see this sled again at an upcoming derby and will take a better look then to figure out what the scoop is on it. The sled ran very well and the track turned over nice and smoothly.
Peter from Roblin, Manitoba
ljm
- Real Name: Lloyd
Re: Camoplast track on a JD Trailfire?
More info on the track would be great.
We will run out of currant options at some point in the near future
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
I talked to another JD sled guy at the Toronto snowmobile show a few years back and he mentioned that you could use a Camoplast track. I still have the catalog I picked up. I forgot to mark the track he pointed out, but I think it must have been a 9796T Durasport 725. The track is 15"x116" with 0.725" lug height and 2.52" pitch. It would be interesting to know what drivers would work along with any other suspension mods needed to make it work.
Greenxcracer76
Looks like it fits the original Yamaha Phazer..sprockets down the center. Anybody know the slide spacing? Looks wider..
1980 Sportfire original owners
1980 Trailfire 440 original owners
1980 Trailfire 340
1982 Trailfire LX
1983 Sportfire original owners
and counting...
1979 Kawasaki Drifter 440
1994 Ski Doo MXZx 467
1980 Trailfire 340
1982 Trailfire LX
and counting...
I did the Phazer track conversion on one of my Liquifires. I may have been the jd guy you talked to mwking. That would have been the fall of 2010.
Mike, the rails do need to be spaced out, Deere stock spacing is 7.625" (I think), and the Phazer track is the more common spacing 8.00" (I think)...
The track has worked out well, I used the drive lugs near the outside of the center belt. That drive axle set up was a breeze to get the flange bolts through the tunnel.
Kenny Waters(boy)
Rochester, NY
'74 X-6
'75 X-8
'75 340S
'77 340 Liquifire
'78 440 Liquifire
'80 Spitfire
'82 Liquifire
'83 Liquifire
Rochester, NY
'74 X-6
'75 X-8
'75 340S
'77 340 Liquifire
'78 440 Liquifire
'80 Spitfire
'82 Liquifire
'83 Liquifire
Greenxcracer76
Ken, e-mail sent.
1980 Trailfire 340
1982 Trailfire LX
and counting...
1980 Trailfire 340
1982 Trailfire LX
and counting...
