Airbox question.
MikeKFM
Airbox question.
Post by MikeKFM »
What is the purpose of an airbox? Is it just an airfilter or is there another purpose? I see people requesting them in the classifieds section so I thought I would ask. I have an 83 snowfire/340.
kreechur
Re: Airbox question.
Post by kreechur »
From what i know they aren't so much an air filter as they are an air silencer. Without one installed the rush of air into the carbs is quite noisy. If you are to run without them i believe (someone correct me if i'm wrong) would require some jetting changes. With it installed there is a bit of air restriction, and without could cause a more lean condition with the easier path of air flow.
  • 2 1970 Moto-Ski MS-18
    2 1969 Mercury 250ER
    2 1971 Evinrude Skeeter
    1 1979 JD Spitfire 340
    1 1980 JD Trailfire 440
    1 1976 JD 400
    1 1974 Scorpion Whip
    1 1989 Ski-Doo Formula MX/LT
    1 1994 Ski-Doo Formula STX
Ryker Carruthers
Real Name: Ryker Carruthers
Post by Ryker Carruthers »
From what I was told as kreechur said, They just silence the air intake. There is no need for a filter because there is no dirt or dust in the snow.
When In Doubt, Throttle Out
MikeKFM
Post by MikeKFM »
Thanks for the replies. When I bought this sled it was off so I guess I will put it on and see what happens.
