80 LF lost lights and tach last spring
I lost power to my lights and tach, all wires tested good to the plug, am i in for an engine pull?
1980 SF 440
1980 LF 440
1981 TF 440
If the women don't find you handsome, they should at least find you handy.
1980 LF 440
1981 TF 440
- Real Name: Greg Cyrocki
Re: 80 LF lost lights and tach last spring
Check the prongs in the plug. Sometimes they push in to the plug and you have to pull them back out with needle nose pliers.
-Greg
'86 Kitty cat
'77 Cyclone SOLD
'83 Sprintfire (wife's sled
'84 Snowfire
'88 Yamaha Sno Scoot
'71 Massey Ski Whiz Special
'86 Kitty cat
'77 Cyclone SOLD
'84 Snowfire
ill have a look, thanks
1980 SF 440
1980 LF 440
1981 TF 440
1980 LF 440
1981 TF 440
Bad voltage regulator could be the cause.
i swapped out the old voltage reg. right after it happen hoping that was the case(i happened to have a NOS VR hanging around) it didnt help anything
would the coils from a 340 liquid be the same as the 440? just in case i have a bad coil i have a good 340 on the shelf i could steal from
1980 SF 440
1980 LF 440
1981 TF 440
1980 LF 440
1981 TF 440
