340s clutches
Livestock 109
- Real Name: Scott
340s clutches
Has anyone ran the stock setup from a 340s on a 340 liquifire? Would this over rev the motor? Or should I just change the primary spring and stay with stock weights? Is the secondary cam the same angle? Thought it might be a good start for a drag setup. Any insight is appreciated before I start messing with it too much. Thanks
Re: 340s clutches
Are you required to use stock type clutching ?
Re: 340s clutches
How are you defining "340/S stock setup"? Or more importantly why a 340/S set up? There are really better options out there in my humble opinion.
Livestock 109
- Real Name: Scott
Re: 340s clutches
Not required to use stock clutches, I just have a number of them. So convenient. I don't know what type of clutch would be that much better as its still a stock motor. I'll be swapping back and forth when not racing it. I have weights with an engagement notch out of a 340/s. Thought I might be able to use them as a starting point.
