Liquifire drive line parts needed
- Real Name: Bob Amber
I am looking to purchase the following parts to repair my 82 Liquifire.
M69015 bearing
M63228 gasket x2
JD 9335 bearing
And possibly M69234 shaft (can be used as long as it's straight.)
Please let me know what you have.
Bob
Sent from my SM-T217S using Tapatalk
M69015 bearing
M63228 gasket x2
JD 9335 bearing
Bob
- Real Name: Lincoln Huffman
Re: Liquifire drive line parts needed
John Deere still sells both bearings 9335 and the other one is a Jd 8665 non greasable Fafnir make a cross for lower greasable , and the top bearing in chain case is a jd8562 the Fafnir bearing is a gra100rrb ag bearing. The cork gaskets can be cut out hope this helps, I have all sitting on my table later Lincoln
Thank you Lincoln.
Lincoln,
Do you have a cross over number for the M69015? It's the bearing on the case side of the actual drive shaft and is the same as the jackshaft bearing on the secondary side. I have been given a fafnir # of RA100RBB but I can't find anyone who carries them.
- Packers29
- Real Name: Andrew Engels
Napa carries them as skf
Secondary side http://m.napaonline.com/parts/PartsDeta ... 0338932775
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
I have purchased all the bearings now but still need a good, straight jack shaft for it. Thanks.
Is it the same as an 81? I think i have one if it is...
Dusty
Dusty
Dusty
Riders:
83 Liquifire
80 Trailfire (grandpa bought new)
79 Spitfire (grandpa bought new)
Projects:
79 Spitfire AKA: FrankenDeere
81 Liquifire
Riders:
83 Liquifire
Projects:
81 Liquifire
I don't think so, they made a switch at like serial # 190000 or so.
The shaft length is identical. The difference is in the length of the shoulder boss to reduce the quantity of alignment washers required and the shaft is purported to be 20% stronger than the 80 - 81 models.
Hey, are you calling my part 20% inferior?!?
Dusty
Dusty
Dusty
Riders:
83 Liquifire
Projects:
81 Liquifire
Riders:
83 Liquifire
Projects:
81 Liquifire
You never know.....it could end up being 20% better!Hemi guy wrote:Hey, are you calling my part 20% inferior?!?![]()
Dusty
After complete tear down, shaft was straight as an arrow. Lesson learned is, don't try while still in a bearing, it might throw it off.
