So I think I mixed up the muffler or the rear bracket for my Trailfire, I know the manifold is correct, the part number is visible. Soooooo is there any way to ID the muffler or bracket by themselves? I think I have all Liquifire stuff, do all the Liquifire mufflers have a flat round spot or an L welded into the top of them near the end by the chain case? The 3 I have do.
I've searched for a bunch of pics online without any real help. Even the pics from my tear down is not real clear. Who thought I would of needed a good picture of the muffler
I tossed a bunch of mufflers and other junk, and my 84 Trailfire muffler may have been in the mix
Muffler Dilemma
Muffler Dilemma
1980 Liquifire
1984 Trailfire LX
1982 Liquifire
1983 Liquifire
1980 Liquifire
1984 Trailfire LX
1982 Liquifire
1983 Liquifire
Re: Muffler Dilemma
I have a trailfire muffler for sale. Going to RWTC tomorrow let me know if I need to pack it- Jim
Re: Muffler Dilemma
So the muffler I have is not a Liquifire and I know the manifold is correct, so it might be the bracket. If I mixed up the muffler it would've had to be from an 80 Sportfire that's the only other sled I junked. I'm not sure if it would fit correctly though??
My problem is the rear of the muffler wont line up with the bracket, it's correct at the manifold and the first mount in the bulkhead, but its too close to the chain case , or the bracket is longer than needs be. Or the 82-84 sled is wider than the 80-81's
1980 Liquifire
1984 Trailfire LX
1982 Liquifire
1983 Liquifire
1980 Liquifire
1984 Trailfire LX
1982 Liquifire
1983 Liquifire
Re: Muffler Dilemma
Bracket flipped over?
Re: Muffler Dilemma
70WT1,
The Trailfire and Sportfire mufflers are the same, and are interchangeable. As the guys said, the 80-84 Liquifire muffler looks the same, but with the "L" welded on it opposite from the outlet pipe. I don't remember if the rear brackets are unique between the Trail/Sport and Liquifire, but I do think they are directional.
I hope this helps,
I hope this helps,
- Real Name: Lloyd
Re: Muffler Dilemma
I just checked and the brackets have the same part number for both a Trailfire and Sportfire.
Would you be able to post some pics?
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
Re: Muffler Dilemma
I got it figured out, the bracket really only fits one way with the upper part mounting over the chain case stud, I found one of the spot welds in the bracket was broke so it had spread apart wider than it needed. So just like the old saying get a bigger hammer
I replaced the bracket and fits perfect now.
1980 Liquifire
1984 Trailfire LX
1982 Liquifire
1983 Liquifire
1980 Liquifire
1984 Trailfire LX
1982 Liquifire
1983 Liquifire
- Real Name: Lloyd
Re: Muffler Dilemma
Glad you got it figured out. That is going to be a nice sled when your done!
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
