I set the point gap at .014” and set the stator plate about midway into the middle of the adjustment window . Then I put the electric starter on and cranked it . I expected no spark but after all that cleaning it has a bright blue spark . My question to you guys is can this engine be timed with an automotive timing light if so would I point it at the marks on the flywheel the one just before the mark with the T ? As it stands now I am going to try and get it to fire as it is now I realize that at this rate it will likely burn down on the snow but my intent is to try and time it before that.Any help would be greatly appreciated !!
Alternate timing on a ccw 400/21
