Liquifire motor mount.
kenv56
Post by kenv56 »
I dont know if any of you remember my problem with my belt flying apart on my 80 liquifire in december, but i believe i found the problem. I took the engine out of the sled and found that the motor mount is separtating, the rubber from the steel.
has anyone seen these for sale?
Are these a common item to fail?
Sorry about the large pics, didnt think they were gonna turn out this big.
Kev,
Unless the steel inside part is loose from the steel outter mount you are OK. I can't tell from the pic if the rubber has delaminated from inbetween the two pieces. I have a few NOS if you end up needing one.
Good Luck,
-Joe Rainville
joerainville@hotmail.com
kenv56
Post by kenv56 »
The steel inner part is loose from the outer part. The middle picture shows it the best.
Thanks for the offer on a NOS one. How much do you want for one? Ill let you know if i end up needing one.
KEN
