76 JD300- first ride of season, early upshift,
grasscutter97
Post by grasscutter97 »
Took it out for about a 15 mile trail run last night, on nice hard pack.
Would a mid range stall, (between 25 to 40mph) be a carb or secondary issue? Engine has about 1000 miles on it since a crank up rebuild, including .020 over pistons, and sals 780 primary was rebuilt too. I also haven't redone the points or timing since the rebuild, could it be a timing issue?
Lastly, when I went to restart after siting for about 5 minutes, engine warm, it took like 20 pulls to get it to fire off, and it smelled real gassy like it was flooding. Plugs were wet. What makes the WDB-31 flood?
A couple things come to mind;
You could have fuel residue in the carb messing things up, or a bad diaphram allowing fuel to be drawn into the case via the pulse hose.
I'd clean and rebuild the carb, sounds like you have an over-fueling issue.
By looking in the Parts Cat. I have to assume your 300 still has points & not CDI??
So If the timing hasn't been Cked/readjusted since reassembly of the lower end?? then yes the timing should be checked/adjusted. You will need a dial indicator, & a buzz box or points timing lite/flash light
grasscutter97
Pulled engine over with plugs out and I got the '2 holed fuel geyser'!!
Didn't know the walbro carbs could flood since the engine is above the fuel tank and there is no bowl, like the mikuni's. Anyways, it flooding.
Got a genuine Walbro kit coming from Image.
Which parts cause the flooding? The orange rubber check valve? Needle / seat?
Dug out my buzz box and dial indicator, so looks like I'll be attempting that this weekend. Haven't done points/timing in ages!
Pulling off the secondary as well, to clean it up, putting new cam shoes on (from Image too), so that should hopefully clear up any upshift issues if there are any.
She'll be on the road doing a blistering 50mph in no time. :lol:
JDFanPa
Post by JDFanPa »
Make sure you set the arm on the inlet needle to the correct specs Id bet this is the problem now if its pumping fuel well also dirt rust can keep the needle from sealing.
