go kart
smitfire
Real Name: Dustin Smit
go kart
Post by smitfire »
i have a 4hp briggs go kart that that the gas line has fell off or something happened inside the tank, it will run when i pour gas into carb but not on the tank
i think the carb has to be taken off and then the gas line to be put back on,
anyone done this and can somebody explain the best way to do so thanks dustin
Spitfireguy
go kart
Post by Spitfireguy »
take the tank off along with the carb and just clean them to perfection make sure everyting is were it should be and slap it back together.
smitfire
go kart
Post by smitfire »
the gas line fell off inside, fixed that today and it started right up, it doesent want to rev up tho, i dont have a clutch on and i know that it will mess it up alittle, but i hold the gas down for a second it will rev up, but any longer it will like bog down and start popping???
going to give this thing some color, you guys got any ideas, i want it to be something john deere
smitfire
go kart
Post by smitfire »
need a clutch, any recomendations???
Liquifire 4/6
go kart
Post by Liquifire 4/6 »
Sweet lookin cart.....it'll look better when it's green. As for a clutch, go for a Comet Torque-a-Verter drive set up. It comes with a drive clutch, driven clutch . belt and an output sprocket. The clutches mount into an aluminum housing plate that bolts right onto the PTO side crankcase cover of just about any briggs or tecumseh. Those little engines put out really good with the torque converter drive....far better than just a centrifugal clutch.
Peter from Roblin, Manitoba
smitfire
go kart
Post by smitfire »
i need the 3 bolts that hold the carb to the tank, anyone have them or know where to get them,
Mr. Deere
go kart
Post by Mr. Deere »
Go to the hardware store and find bolts that will fit into the carb and that are long enough to go through the tank. Also might want to get a new gasket first. BOB
smitfire
go kart
Post by smitfire »
they had like a square end, hardware hank have something like that??? or anything will work with the threads right
smitfire
go kart
Post by smitfire »
which one is further apart in chain link spacing-35 or 41 thanks dustin
go kart
#40 chain is larger than #35 but #41 is smaller than both.
Makes no sence to me but that is the way it is.
jrbsnow
go kart
Post by jrbsnow »
#40 and #41 have the same length between pins, but #40 is wider and more heavy duty. #35 it the smallest of the three.
Jay
go kart
Isn't #41 like bicycle chain?
smitfire
go kart
Post by smitfire »
i got a 35 clutch and the sprockets were to small on the clutch( chain didnt fit), what is the next size to try, i can post pics of the chain and old clutch if needed thanks dustin
smitfire
go kart
Post by smitfire »
heres the chain
smitfire
go kart
Post by smitfire »
heres the broken clutch
