power an responce
storm_00
power an responce
afternoon fellas,went for a ride today an I am in some need of tweeking but more than that I think I have some clutching issues what can I do to increase my throttle resonse,an how do I get that snap back in my 340 liquifire ,I figure it has something to do with the weights in the drive clutch an the spring in the driven any cheap suggestions would be greatly appreciated
power an responce
You want a CHEAP suggestion, Don't drive it!
Your DRIVE clutch is like a 8000 RPM hand granade, If it needs repair & you can't afford to repair it or replace it, Well ??
If you just got the sled & or haven't looked at the Drive clutch in many years you need to do so, first by removing it & disassembleing the front cover once you do this the spring tension will be off the moveable sheave, at that point you will be able to visually inspect the ramps/weights for worn bushings or pins/bolts, you will also be able to look at the rollers to see if they are also extremally loose & for cracked or missing clutch buttons, also you will be able to ck the movable sheave for a bad bushing & or cracks in it. you will not however be able to repalce the clutch buttons or rollers unless you remove the spider. to do so you will most likely need someone with the correct tools to do so as the spiders are ussually loc-tited on.
Ken
Ken
storm_00
power an responce
thanx its kinda like that song I built it one peice at a time lol the clutching is the second to the last thing on my list to fix lol did the driven lastnight an well guess what we start on tommarow man the wife is gonna love me lmao but then again she did say make a list of things you want for xmass
guess I will need to put a clutch puller on that list lmao
thanx for the info
thanx for the info
power an responce
Make sure she spends enough to get the good puller not the cheap ones, it'll be worth the extra money in the long run.
Have her understand that haveing the sled will like "Hey look at it this way it keep you out of her hair"
Ken
Ken
