Pinstripe removal question
I know that the painted on pinstripes were all the rage in the 80's. I never liked them. But my question is what product will take these painted on pinstripes off? Or will they even come off without major work?
Thanks......Robb
Thanks......Robb
Robb I have had some luck with using automotive lacquer thinner on a rag.... but very sparingly. Also try wet sanding them off with 1500 to 2000 grit. When you are done give the whole hood or tunnel a good buffing...low rpm on the wheel with a medium or fine cut compoud to get the paint uniform in colour again.
Dave
Dave
1978 340 CC Liquifire
Robb, I don't think I'd take Dave's advice. Afterall, he can't even spell color (colour) right!!!!! (eh!) DA
Don, I did gets me a college edumacation!
Easy Off oven cleaner....I have used this on the fire series to remove painted on numbers..spray it on watch it bubble wipe off then wipe with thinner then wax.I have never had a problem doing this but try a little spot before spraying a big area!!
Mark.....
Thanks for the advice. I'll sprae a small areas and watts foor a colour chanje.
Robb
Robb
LMAO
Good one Rich! DA
Hey Dave, I sure hope you're taking this in the light that was intended.....pure jest. Didn't mean to make you the centre of attention!!!! We love our Canadian neighbors. DA
It's ok Don I don't mind being the CENTER of attention.
I love my U.S neigbors too. Except that guy named Bruce!
:o
:o
Mark,
Just want to give you a heads up that the Easy Off oven cleaner trick worked nicely. The sled I was working on had a ton of those pesky stripes on it. I sprayed the oven cleaner on, let it sit for about 20-30 minutes and worked them off. Had to do it twice but worked nicely. Also, it never damaged the paint on the original hood. I masked off the decals because I didn't know if it would ruin them. I washed and waxed the hood once I was done to get any of the residue off. Thanks for the tip........................................
Robb
Robb
