295/S Snowflap Part # M65186
Anyone have a NOS or very good one that can post some pictures of what they are suppose to look like???
thanks
MARK
Post by MARK »
Ken,let me look tonight when I get home I have a NOS flap but not sure if it's for a 295/s or 340/s..Mark.
MARK
Post by MARK »
Ken, The NOS flap I have is #M65553 I believe that is for a 340/S sorry :cry: Do you need one for a 340/S?? :think:
340s
Post by 340s »
Hi Kenny,
My 295s is in my dad's garage right now. I can get a good pic in a couple of days but to give you an idea, here's a pic for now that you can enlarge. Its material is just like the 340/s original flap, and is nothing special to look at.
On that note, I am looking for a couple of 'leaping deere' flaps for my x8. Anyone got a couple for sale? Or repops?
Craig
Mark, Yes I will need pictures for one of those also (340/S), (Also does it have the Part # stamped into the flap someplace???) Unless you want to SELL me that one???? call me 612-325-8527
Craig, Are you sure that is an original 295/S flap?? I don't know what they are suppose to look like???? That is why I was hoping someone had a NOS one so we would now exactly what they looked like.....
I found a Deere flap today that is plan (no running Deere) with either 295/S or 340/S paint on the back But I do remember taking it off a 295/S tunnel. It has the shape of a running Deere flap (only thinner).... were they used on the 295/S??? or was the OE 295/S flaps shaped different like the 100 series were????
340s
Post by 340s »
340/s flap. old, but gives you the idea....
The one I found was about the same outside shape as the running Deere ones, Might be a little smaller, but for sure not a 340/S not that long.
Now I'm really confused
Craig, you have a picture of that 295/S from the back????
340s
Post by 340s »
Hi Kenny,
Sorry I think i might have confused you and myself too LOL. I meant to say I think the 295/s and 340/s flaps are both 'plain' with nothing on them. But, I THINK the 295/s flap and the 'leaping deer' flap such as on the '73 x8 are the same size. The 340/s one is a little wider, more like the dator leaping deere one. I could be wrong though and so i wouldn't bet the farm on it. I will get an actual measurement for you in the next couple days unless someone can clear it up for 100% for us.
Craig
Craig, the original 340/S one if I remember right was longer & drug on the ground just like the one in you photo & was a different shape than the replacement leaping/ running Deere for it....
Although the one that I have might have been a cut down version of the first gen 340/S flap???? I'm just guessing though
75rat
Post by 75rat »
Hi Kenny,
This is the best photo I have of an original 295/S snow flap. It's a totally different shape than the one used on the 00/JDX series sleds and outside shape is similar to the 340/S and later model Deeres. As previously stated, it's plain with no logo and look's a lot like a 340/S flap. But, I've never put them side by side to see how close they really are.
Jim
Jim, that is more like the one I have, at least from what I can tell from the angle ...
340s
Post by 340s »
Hi guys,
I measured the flap on my 340/s this morning and took a good picture. The measurements are a height of 14 3/8"x width of 15" (across the top where flap mounts).
The flap also has a width of 21 1/4" across the bottom at its widest point. I agree that this flap is probably a little longer than the leaping deere ones since the 340/s flap drags on the snow (it doesn't touch the floor in this pic since I have the sled elevated a little). I think the dragging on the snow explains why the flap has curled up a little at the bottom as you can see in the pic.
Man I'd like to track down one of these someday! Hope this helps out. I'll get a pic of the 295/s flap and measurements this weekend.
Craig
Craig, I'm looking for the right material, if found, we will have some by winter.. For both the 295/S & 340/S, That is as long as I can come up with a good 340/S one to pattern off of.... Unless someone else has something in the works??? Speak now or forever hold your peace!
340s
Post by 340s »
Hey Kenny,
Great idea to do up the flaps! My 340/s flap isn't perfect but my 295/s flap may be pretty darn good still. Should these flaps be of any use to help you out, just let me know and they're yours to use for a pattern.
Craig :beers;
I have one of Wanie's leaping Deere flaps on my 340S at the moment.
If lower the suspension ( and I plan to ), then it will be a bit short.
I have what appears to be an original flap on the other machine.
