295/s motor parts
Vector Boy
295/s motor parts
hello, i'm new here and looking for help in locating crank seals and gaskets and maybe piston and rings for two 295/S 's that I am restoring. I have three motors (one is parts) for two sleds. for now would like to get one running and driveable for 2010 waconia Mn. event.
295/s motor parts
Gaskets can be purchased from Windosa, Cometic or other parts suppliers, Seals can also be purchased, the size of the seals should be stamped on the seal ( it should read like 25-62-10 or whatever ) I believe on the 295/S there are 2 different sized seals, so you need to look at both, also if the cranks has been sitting for a bunch of years it would be a good Idea to send them out & have the bearings cked & the center seals replaced.. we have a crank place as one of the sponsors of this website CRANKSHAFT SERVICES..
