Quick Question on fuel
Mr. Deere
Post by Mr. Deere »
I think my fuel pump is on its last leg so I was thinking about replacing it. I am faced with two options. First I run two separate pumps one for each carb. The second being one of these guys. Mikuni DF62-702. It flows 65 liters an hour, 17.2 Gallons!!!!. Should be plenty. Only question is is it too much??? Will this Flood the motor??? I was thinking it shouldn't but I am unsure to tell the truth. Thanks Image
Re: Quick Question on fuel
one pump should do the job Bob.
Mr. Deere
Post by Mr. Deere »
Ok so that single double pumper should be good. Not too much fuel for the two carbs??
What Brain said... :silenced:
Bob, I thought we broke you years ago from asking the same question over & over & over, Until you get an answer you want to hear ?? :bonk: :bonk: :bonk: :doh: :doh: :doh:
Why would you want to put a fuel pump on a older sled that hasn't been proven to work on your particular sled? Especially when the OEM style pumps are still available??
:bonk: :wall: :wall: :wall: :wall: :wall: :wall:
Mr. Deere
Post by Mr. Deere »
Sorry I was just making sure he didn't think I said I wanted to run two of the big guys. I worded my original post a little funny. I never though of that Ken. Maybe these motors don't create enough Impulse to draw what that pump needs. I think I will get a genuine Mikuni Rebuild kit for mine now and later on down the road switch things up a bit. I just want to get it running and then I can tie up all the loose ends next summer when I am out of school and have a little more cash.
Mr. Deere
Post by Mr. Deere »
I think I want the $13 dollar one if Im not mistaken right??? http://www.psep.biz/store/fuel_pump_repair_kits.htm Thanks.
If you have the "pentagon" type pump like the picture in your first post, you want the following:
REPAIR KIT FOR MIKUNI PENTAGON FUEL PUMP PU451457 7.95
REPAIR KIT FOR PUDF-52 OR MDIDF52T (ROUND) , ADRK52 ,, $13.75 ,, I would think should work
The way I read it the other kits below are other than genuine Mikuni??
I think, but Doesn't the Newer Liquifires use a pump with more plates in them ( meaning there stacked higher??)
So make sure the rebuild kit has gaskets to go between as many plates as your pump has..
Mr. Deere
Post by Mr. Deere »
Ok thanks guys. Mine has one plate sandwiched in between the base and cover so I believe its a standard one. I think its from a different app but it still works the same. Harley I was think of trying that guy but I don't know how well it would work.
bob15
Post by bob15 »
Bob, if you find that yours doesn't work with the rebuild kit and you need a fuel pump, look at the Mikuni DF52-73. The outlets are bent 90° up, instead of straight out. Just another option.
Also, check your messages/e-mail
bob
Mr. Deere
Post by Mr. Deere »
Ok thanks. I wanted to order this the other night but forgot. I will get it done today. Bob I don't have any Messages. I don't remember seeing a email from you either.
