Mikuni Butterfly Stock Settings 79 Spitfire
The 79 Spitfire is getting used quite a bit. The other night I had it up to 62 MPH, the girls haven't had it out in an open enough area yet to try in high speed passes... Anyway, it is a bit fussy when it comes time for it to idle (for driver changes) and then when it dies, it sometimes is hard to start. Since, I went through the whole thing last year and basically restored it to new, I am pretty sure it is a carb adjustment issues. So I am hoping someone can detail the factory settings for the carb, so I can start from there. Also what main jet should I be using here in the midwest, its currently a 180. Thanks in advance for any help that might be provided.
- johnnycyclone
- Real Name: Terre
Re: Mikuni Butterfly Stock Settings 79 Spitfire
www.vintagesnow.com has an online service manual for the 79 Spitfire. This will give you the factory settings.
Terre
Terre
Thanks, didn't realize that had been added. Awesome!
