Trailfire 440LX - Oil pump
JD_Sledder68
Post by JD_Sledder68 »
When I picked up this Trailfire, someone had already disconnected the oil injection pump and ran it on pre-mix. Since the oil tank, lines and cable are already gone and the oilpump itself is just capped off, can I just remove the oilpump all together and fabricate a block off plate to mount in it's place??
The reason I ask, is that the pump makes noise when the engine is running, and I suspect it is due to lack of lubrication. It is probably eating itself for lunch without oil in it....right??
Brian Redick
1978 John Deere Liquifire 340
Re: Trailfire 440LX - Oil pump
Sure, you can just remove the pump and drive key.
JD_Sledder68
Sweet! I figured as much since it isn't driving a water pump behind the cover....but wanted to be sure before attempting it. Someday I may re-acquire all of the parts and put it back together.
Brian Redick
jdsnowfire
Post by jdsnowfire »
i whould buy the parts (pump and recoil) off of you. and can send a regular recoil if you are interested.
